Jump to content
  • Log in with Facebook Log in with Twitter Log in with Windows Live Log In with Google      Sign In
  • Create Account
  • iPhoneforum pe FaceBook
  • twitter
  • Canal youtube
  • iPhoneforum pe googleplus
restore problem
  • This topic is locked This topic is locked
10 replies to this topic
#1 OFFLINE   Clone
Clone
    Incepator
  • Membru
  • 9 posts
  • iGadget:iPhone 4
  • Gender:Male
Neutral
Posted 16 March 2011 - 03:04 AM
am facut o prostie aseara, am vrut sa pun cu tinyumbrela 4.2.1 si nu a mers, asa ca am incercat 4.3 care l-a instalat dar a ramas in DFU. (aveam 4.1)
am salvat SHSH inainte, dar nu pot sa mai fac restore
ce pot sa fac acum ?
nici upgrade oficial nu merge, imi da eroarea 1013
  • 0
#2 OFFLINE   Shteff
Shteff
    Young Padawan
  • Admin
  • 4,073 posts
  • iGadget:iPhone 3GS, iPhone 5s, iPhone 5c, iPhone 6s, iPad 4, iPad Air, iPod Classic, iPod Nano, Apple Watch Series 2
  • Versiune iOS:10.1
  • Mac:MacBook, MacBook Air
  • Apple TV:Apple TV 3G, Apple TV 4G
  • Operator:
  • Jailbreak:Nu
  • Gender:Male
Excellent
Posted 16 March 2011 - 07:41 AM
Telefonul e codat, ce baseband ai pe el?
Daca nu este de la baseband, incearca sa editezi fisierul hosts din windows\system32\drivers\etc astfel incat sa ramana numai linia "127.0.0.1 activate.adobe.com" sau nimic dupa liniile care incep cu "#".
Daca este de la baseband, adica daca ai 6.15.00 pe el, este un tutorial prin care scapi de erori, tu neputand face update sau restore la firmware oficial.
Sper sa te ajute :)
  • 0
#3 OFFLINE   ovidiu39
ovidiu39
    Membru
  • Membru
  • 177 posts
    • Time Online: 67d 23h 37m 59s
  • iGadget:iPhone 5c, iPad 2, iPad Mini Retina
  • Operator:
  • Jailbreak:Nu
  • Gender:Male
Donator
Neutral
Posted 16 March 2011 - 12:49 PM
salutare! eu am reusit sa scap de eroarea 1013prin urmatoarea metoda ,valabila pt windowsFix iTunes Error 1013 When Updating iPhone 4 to iOS 4.2.1
By Fahad Khan | November 24th, 2010
If you have tried updating to the recently released iOS 4.2.1 update on iPhone 4 and encountered Error Code 1013 or Error Code 1611, then you are a not alone. This has been a common issue across all iOS devices updating to iOS 4.2.1 and Apple Support Discussion forums are full of users complaining about this issue.
This bug has apparently been reported to Apple but if you don’t fancy waiting for an official fix, you can follow this guide to try and successfully update your iOS device to 4.2.1. Before doing so, you may also like to try and restore using a different computer.
Warning Note: This will result in your iPhone 4 baseband being upgraded to the latest version.
How to Fix Error Code 1013:
Mac OS X:
Step 1. On your Mac, go to your “Applications” folder.
Step 2. Now navigate to the “Utilities” folder.
Step 3. Launch "Terminal".
Step 4. Type "sudo nano /etc/hosts" (without quotes) and hit return.
Step 5. Enter your password
Step 6. Use the down arrow key to find the “gs.apple.com” entries. Once the cursor is in front, make sure you comment out the line(s) by entering “#” in front of the text.
Step 7. Save the file by pressing CONTROL+O.
Step 8. Exit the nano editor by pressing CONTROL+X.
Step 9. Restore your iDevice.
Windows:
Step 1. Start –> Programs –> Accessories
Step 2. Run Notepad or WordPad
Step 3. Click “Open..” from File menu.
Step 4. Browse to Windows/System32/drivers/etc
Step 5. In "files of type:" select all documents
Step 6. Open "hosts"
Step 7. Delete all line that has "gs.apple.com" or something like that
Step 8. Hit Save
Step 9. Restore your device
[@Gustasn0w for Windows steps | Tech-Exclusive for Mac steps]
You may also like to check out:
iOS 4.2.1 Final Version Jailbroken Using Updated Redsn0w 0.9.6b4 [How to Guide]
Download Apple TV 2G 4.1 Software Update to Stream Video from iPhone to TV via AirPlay
How to Downgrade iOS 4.2.1 to 4.1 / 4.0.2 / 4.0.1 on iPhone 4, 3GS, 3G, iPod touch and iPad
How to Jailbreak iOS 4.2.1 GM on iPhone 4, 3GS, 3G and iPod touch with Redsn0w [Guide]
You can follow us on Twitter or join our Facebook fanpage to keep yourself updated on all the latest from Microsoft, Google and Apple.
ASA AM REUSIT EU DUPA CE AM DAT RESTORE LA UN IPHONE4 DAR ATENTIE !!!NU AVEA JAILBREAK /UNLOCK FACUT ERA VB DE UN RESTORE CURAT DIN ITUNES PT CA ERA CODAT ORANGE RO SI IL FOLOSEAM CU SIM ORANGE.BAFTA
  • 0
#4 OFFLINE   Poison-psN
Poison-psN
    Membru
  • Banned
  • 326 posts
    • Time Online: 1d 3m 42s
  • Gender:Male
Neutral
Posted 16 March 2011 - 01:37 PM
ovidiu39: Solutia ta este buna doar pentru cei care nu depind de unlock.
Clone: ar trebui sa spui ce telefon ai, ce firmware, daca depinzi de unlock, daca ai baseband de ipad si daca ai SHSH salvat. Pentru a te ajuta, avem nevoie de mai multe informatii, nu ti se pare normal ?
  • 0
#5 OFFLINE   Clone
Clone
    Incepator
  • Membru
  • 9 posts
  • iGadget:iPhone 4
  • Gender:Male
Neutral
Posted 18 March 2011 - 12:25 AM
scuze de intarzariere dar l-am rezolvat intre timp
am un iphone 4, baseband 02.10.04, firmware 4.1 si e unlocked.
am rezolvat prin update la 4.3 din itunes. si acum am baseband 04.10.01
  • 0
#6 OFFLINE   Papai
Papai
    Incepator
  • Membru
  • 2 posts
Neutral
Posted 18 March 2011 - 02:49 PM
buna.am si eu in iphone 3gs,si s-a stins,iar acum cand il pornesc imi apare doar marul de la apple.Am incercat sa i dau restore cu itunes,dar imi da eroare,oare ma puteti ajuta sa il fac?
  • 0
#7 OFFLINE   Tyler Durden
Tyler Durden
    Single-serving friend
  • VIP
  • 4,722 posts
  • iGadget:iPhone 6s, iPad Air 2
  • Operator:
  • Jailbreak:Nu
  • Gender:Male
  • Interests:Fight Club
Excellent
Posted 18 March 2011 - 04:09 PM
Detaliază mai mult.Ce eroare primeşti când dai restore?Ce firmware ai avut?Etc.
  • 0
"You're not your job. You're not how much money you have in the bank. You're not the car you drive. You're not the contents of your wallet. You're not your cenzurat khakis. You're the all-singing, all-dancing crap of the world. . " Tyler Durden
#8 OFFLINE   kofe
kofe
    Incepator
  • Membru
  • 24 posts
    • Time Online: 46d 21h 6m 36s
Donator
Neutral
Posted 02 July 2011 - 12:30 AM
Salut. am si eu o problema: Ieri telefonul mi s-a stins pur si simplu in timp ce ma jucam pe el si n-a vrut nici in ruptul capului sa mai porneasca daca il pun la incarcat porneste dar imi arata mesajul ala cu cablu itunes, si scrie emergency only...
Am incercat sa ii fac restore, l-am pus in recovery mode, i-am dat sa faca restore, dar ma lovesc de eroare 1611. Am incercat cam tot ce am gasit pe net despre eroarea asta, si nu mai am solutii... pe site la apple scrie ca s-ar putea sa fie ceva probleme hardware... Mi-e teama sa nu fie asa. Am uitat sa mentionez, telefonul e iPhone 4 16 GB neverlocked, rulam pe el ios 4.3.3, si aveam jailbreak cu redsnow. Ce sa-i fac, ca am dat o caruta de bani pe el si acum stau si-l tin ca bibelou...
  • 0
#9 OFFLINE   Marius
Marius
    iGeniu
  • Admin
  • 13,554 posts
    • Time Online: 1h 4m 24s
  • iGadget:iPhone 6 Plus
  • Mac:MacBook Pro
  • Operator:
  • Jailbreak:Da
  • Gender:Male
Excellent
Posted 02 July 2011 - 06:03 PM
Verifica pls ca in Hosts sa fie totul ok.
Incerci recovery cu un custom firmware ?
  • 0
Ma puteti urmari si pe: Twitter, Facebook sau Google + Vrei oportunitatea de a gastiga produse Apple aproape gratuit, FreebieJeebies iti ofera o astfel de oportunitate. Daca vrei sa afli mai multe despre sistem, cum functioneaza si ce trebuie sa faci pentru a participa, intra aici unde am postat exact pasii ce trebuie urmati.
Succes.
#10 OFFLINE   popica
popica
    Incepator
  • Membru
  • 1 posts
    • Time Online: 50d 5h 24m 1s
  • iGadget:iPhone 4
Neutral
Posted 06 August 2011 - 02:14 PM
Am un iphone 4 Baseband 4.10.01 - initial avea firmware 4.3 si nu era activat, am incercat sa-l activez cu Redsn0w 0.9.6rc19 dar am folosit firmware 4.3.3 si a intrat in dfu mode. De atunci am incercat toate variantele de instalare si tinyumbrella-5.00.09, adevaru ca nu are decat shsh ptr 4.3.5. Marea mea problema acum e ca nu se mai deschide nici display-ul, nici macar in timp ce instaleaza (isi revenise la un moment dat dupa care iar a murit). Daca ii dau just boot theathered right now cu Reds0w porneste si isi da restart imediat dupa in dfu mode si bineinteles ca ecranul ramane la fel inchis (imi dau seama ca porneste dupa ITunes si sunetul de pornire). Telefonul este nou nout l-am luat cu tipla pe el in cutie.
  • 0
#11 OFFLINE   InSecret
InSecret
    Membru
  • Membru
  • 408 posts
  • iGadget:iPhone 3GS, iPhone 4
  • Gender:Male
Neutral
Posted 06 August 2011 - 04:15 PM
Imi suna destul de urat eroarea... din cate imi amintesc am patit-o si eu si acum... sincere regrete pentru fostul iphone 4... anyway intr-un final reusisem sa il aprind dar se stersese imei'ul si iccid-ul cea ce inseamna ca eram foarte limitat ... fara wireless fara bluetooth fara telefon etc... Hai acum sa iti zic cum am reusit sa il fac... am deschis tinywmbrella, am dat start server dupa care l-am bagat in powned dfu cu redsn0w si am inceput un restore cat mai clean (adica direct softul cu care vine initial iphone 4) incearca cu iOS 4.01 sau cu 4.2.1ar trebui sa mearga lejer dar mare grija.. fa pe un calculator care nu a mai avut iTunes instalat si sa aibe internet bun gen fiberlink de la rds sau ceva de gen.... Mai mult pot sa iti zic doar ca iti tin pumnii sa nu primesti si tu eroarea 23 . Mult succes si sunt curios daca iti va merge daca nu si esti din bucuresti luni poti veni cu el la mine si te ajut eu.
  • 0
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
evomag.ro
Parteneri iPhoneforum:
